Recording/Not Recording
  • 2835 Views
witchypoo
Camera will record and put in library but then the recording icon shows orange and won't move out of recrfing mode to pick up next activity. I have to manually hit the live record and stop it for the orange record icon to go back to black. I tried turning camera off remotely. Should I re_sync? Or turn base station off
App or browser? Have you tried both as well as logging out and back in? Restarting the base may be useful.
If a power button reboot ( off then on ) doesn't fix the issue, I would remove the camera ( remove device) pull battery , then replace ( reset cam ), then bring the camera back as new ( to rebuild the mode )
Arlo123
Yes, try to powercycle the base by leaving it unplugged from power outlet for about a minute. If camera is still now working properly, try removing the camera from account Settings > My Devices > Affected Camera > Remove Device. Once camera has been removed, powercycle the base for 1 minute, then re-sync teh camera. That should fix the problem. In the event that camera is still not working properly, please contact Arlo support hotline so that they can assist you.
  • 2836 Views
