Problem reinstalling Arlo Pro2 Base Station VMB4000
  • 2 Replies
  • 819 Views
NorCalBenny
I could not re-add my Arlo Pro/Pro2 Base Station VMB4000 after accidentally removing it.
I followed the instructions, pressing the Factory Reset button with a paper clip many times with no success.
I found a community note to use a paper clip to press the Factory Reset button and hold for 12 seconds.   The Arlo App on my MacBook Air could then discover the Base.  I then proceeded to add the cameras.
Finally, Success!
Base Model:     VMB4000r3
macOS             Tahoe 26.3.1
BrookeN
Thank you for sharing this information with the community. I am glad it is now resolved. Have a great rest of your week.
NorCalBenny
Yes, the solution was to hold for 12 seconds when pressing the Factory Reset button with a paper clip.
  • 2 Replies
  • 819 Views
