My log in page is just whirring, has been for at least an hour now. Not good when I need to check if something has just been taken from our garden! Grrrrr!
Anyone else having issues? Any suggestions please - need to take a look soonest!!
Login is working fine for me (both the iOS app and my.arlo.com). https://status.arlo.com reports no issues as well.
Are you still seeing this?
Hi Stephen, good to hear from you, thank you! I am now finally in however, now have another 'problem'!
I always login via my desktop, not the App (as my phone is so very old, it would not cope)! Before you ask, yes, I have activated the dual verification thingy majiggy - all hunky dorey there! but now struggling to alter my camera settings as one is peculiarly sending sound detection messages, that I don't particularly wish to receive, but no motion. Any ideas how to alter the settings-forgotten how I set it all up in the first place now as was ages ago?!
Start by looking at the camera rule in the modes that you use. https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
You might also want to use the motion detection test, to make sure the sensors in the camera are working properly. https://kb.arlo.com/1114344/How-do-I-use-the-motion-detection-test-for-my-Arlo-device
Hi again
That's just it, I can't see the modes option to see exactly what settings I have set up 😞 and no memory!!
Any ideas?
Thank you Stephen
It's not hard to find. In the web interface it's at the top of the page.
I'm obviously not on the right page then.....??
Mmmm, that should have a photo attached of what I can see.....how did you do that?
I used the photo icon at the top of the forum page.
The screenshot above is the top of https://my.arlo.com/#/cameras
