Pro2 Live view shows white screen with one red dot using Edge browser
  • 5 Replies
  • 1780 Views
shadowb
All was working fine until recently.  Now live view shows a white screen with one red dot in the upper left corner.  It works fine using Chrome and it works using Edge and Chrome on my laptop and on my phone.  Must be something in the Edge version on this computer but I don't know where to look - latest version of Win10.
5 REPLIES 5
ShayneS
Have you tried updating the application or clearing the cache?
shadowb
Edge is up to date.  Cleared cache - no help.
ShayneS
@shadowb
Can you provide a screenshot here? Do both cameras have the same issue?
shadowb
Yes both cameras the same.  Here is screen shot.
ShayneS
Have you checked for any updates on your PC (To check for updates, select Start > Settings > Windows Update , then select Check for updates. If updates are available, you can choose to install them.)
You can also check to see if your drivers are up to date.
  • 5 Replies
  • 1781 Views
