I have a completely functional camera frow which the 1/4 x 20 insert has gone missing. Hate to replace the entire thing for a small part.
Any advice as to where I can obtain this part and glue back in place?
I can not use the magnetic feature, so this is my only option.
You're gonna have to look around for that - good luck. This search may or may not help:
Thank you
