Is there a way to adjust the recording time after the camera detects motion? As of right now it will only record for about 12 sec and stop.... I would like to extend it to about 30 sec
If you edit your running mode such as armed, then edit the camera rule, then edit the recording option, you can select a fixed record length of 30sec.
Thank you very much! That work!
