Pro 2 doesn't charge when battery is in & plugged in USB adapter. Flashes blue and not discoverable.
  • 1 Reply
  • 889 Views
lyp75
One of my Arlo Pro 2 is not working in that:
1. It doesnt charge when the battery is in and plugged to usb adapter
2. It only flashes a blue light once when I plug the USB slot but then does nothing
3. The camera is not discoverable on the iOS app
please help! My other 3 seem fine
Start by swapping batteries to see if it's the camera or battery. You'll likely need to use the Contact Support link at the bottom here for a hardware problem.
  • 1 Reply
  • 890 Views
