Three of my cameras overlapping the same areas are up to 30 seconds out of sync running live??? What's up with that?
Hi @elixibob
Are you still experiencing this issue with your cameras?
What troubleshooting steps have you tried so far? I do not want to suggest anything you may have previously performed.
Yes, this happens frequently. I haven't a clue as to what troubleshooting steps there might be. Any suggestions would be welcome.
You can try rebooting the cameras if you have not already. This would be the simplest 1st trouble shooting step to take. You can open the battery door > remove > Re-insert the batteries & test your live streams again for any lag.
Also, how far way are the cameras from the base station?
