Pro 2 System with Current Doorbell Camera
I have an Arlo Pro two system with 5 cameras. If I purchase a newer doorbell camera with subscription, will it work with my Pro 2 base station and will I be able to add the Doorbell camera for just the monthly rate for the one camera without paying extra for going over 5 cameras.
Yes. The limit is 5 unsubscribed cameras in the account.
You can connect the doorbell directly to your home wifi (with no base).
If you prefer to use the base, you can check the compatibility here:
Generally VMB4xxx bases are compatible, but VMB3xxx bases are not.
Thank you sir.
