This has been an issue since day one, but other pressing issues put this on hold until I wanted to use it recently.
So if I am stood near the Pro 2 in WiFi or 4G if I enable the talk feature it works and it's not loud be clearly audible.
Move away from the house and nothing, a very faint whisper.
Volume is set to max, base station restarted, cameras and all truer IOS and Android - the same. Even from a PC the same.
Anyone else with the same issue.
The sound is much lower on the Pro 2 then the pro one for me also. I hope they can fix it along with the night vision problem
