Arlo Pro 2 has been nothing but problems from the start. I am using the latest firmware for the cameras and base station and all 4 of my cameras receive AC power with the Arlo cables and adapters. First issue is that the notifications are very delayed. When first installed they would be almost instantly. Now they are coming with delays ranging from 10 min to sometimes as much as an hour late. These are notifications for cameras sensing motion as well as the Geo Fencing stating that the system is in away mode and armed. I have spent hours reading about others that have had similar issues and what they did to fix them. The Community has been far better than the support people that are paid to know what they are doing. I have done everything from removing the cameras from the system and then adding them back again, moving the cameras into the area for cameras that aren't active and then activating them back again. I have uninstalled the app and restarted my phone and installed the app again, I have also restored the system to factory settings and completely set it up from scratch. The majority of these did nothing for the issues I am having. If it did anything at all it only took a short time to go right back to where it was before. The latest issue is when I go to view my cameras through the app or the website all 4 cameras will say they are Offline, however the base station is showing they are connected and the status light on the front of the base station is solid green. The cameras are recording events in the library. If I uninstall the app, restart the phone or computer and reinstall it I can usually view I live video from the cameras, but this is a huge hassle to go through each time. If I didn't spend a fortune on this system I would toss them in the trash. I have used old cell phones as security cameras with better results than this $500 Arlo Pro 2 system. I purchased the 4 camera system during the Black Friday sale at Best Buy, which was almost 6 months ago. I have a subscription so that the videos are available for longer time periods, I believe it's 30 days. By the way it is worded in the support section I can't determine if I have support help past the 90 day period or not? If anyone can help me with this I would sure appreciate it. I spent 4 hours last night reading what others have done that have had similar issues but didn't come up with anything that was different from what I have already done. Thank y'all very much.
Kevin
Delayed notifications are usually due to 2 things - 1) use of Arlo Smart (deactivate the cameras in the Smart settings) and/or 2) phone battery optimizations (disable them in the phone settings for the app).
Thanks for your help
Might be an idea to review the setting in the user manual for the phone that may explain why.
Hi @NCHornet
You may contact support without being charged. I have provided the link here for you. Arlo Tech Support
