Pro 2 Nigh.t vision is always active
Hi,
My Pro2 keep on the night vision activated even on day time but prettry sure the light is sufficent to the camera although im using in house.
This can be solved by de-grade the video quality from setting but It turn back on in a few hour later i check it again. Anyone same??
Please help !!
Are you saying the video is black & white during the day or that the IR illuminators stay on all day? Have you got the camera plugged in to AC power? Have you tried removing the battery for 10s and reinserting it?
and all you mentioned i did already and it still doesnt work.
so I decided to disable the night vision feature. But just I notice the image come to colourless again...... any suggestion?
Oh right. I think I understand what you're saying. The video is always black and white?? If so, this is due to low ambient light. Black and white in low light allows more detail to be seen. If you were to shine a torch or your phone torch at the front of the camera, it would change to color video. Basically, it's too dark in your room for the camera
