When my Arlo Pro 2 camera are plugged to the power adapter so extra features can be used, should I remove the battery and only use the adapter, or keep the battery inside the camera? If the answer to keep the battery inside, dose a continual use of power adapter damage the battery?
No problem leaving the battery inside. There is battery management circuitry inside the camera to prevent any damage to the battery.
Thank you so much for the quick replay👍
