[Potential Fix] When watching camera live, showing motion detected notification
Someone posted this
Motion detected "notification when checking camera status or switching to live view
Basically when you go to watch your camera live.... it will bring up a motion detected notification and annoy you and whomever else has access like your spouse. So I found a way to fix it. So go to the main screen in the app select the ... buttons on the camera which is acting up the select device on switch and turn it off for 30 seconds. Then turn it back on and try viewing your camera ... I just tried it like 30 times and it didn't go off once. But before it was like every 3 out of 4 times
0 REPLIES 0
