kgmitton
I now get a pop up ad each time I log in or switch to my devices page.  Add is selling 30 days cloud recording, etc.  I did not get this at all until I set up a friend's new arlo system using my computer (not sure if the 2 things are related or not).  I'm running the app on my MacOS desktop.
There is no option to forever stop showing -- only options are Try later, Do a free month, or enter Arlo smart code.
Help!!! This is REALLY annoying.
28 REPLIES 28
JessicaP
We appreciate everyone's patience about this. A fix has been released that resolves this issue. This fix is automatically applied and does not require any interaction.
If you're still experiencing the issue, please let us know.
valglad
It's fixed now. Thank you!
HazelsNuts
Thank you. I am no longer experiencing the popup.
If you can get the same person who fixed this issue to take a look at the "Set PC as Trusted Device" issue I would be most grateful.
alchemist50
