The PIR detection is based on heat and the pixel (plugged in Arlo Pro 2) is based on any movement in that zone.
To prevent false triggers, reduce the sensitivity and make use of zones so that you exclude areas that you aren't interested in.
If you want to reduce false alarms, then use PIR. Delete all your zones. Aim the camera so people and cars in the driveway trigger the camera.
Johnny290 wrote:
I know but I like seeing the whole neighborhood I just wanted to have zone in my driveway and still be able to see everything else but it's not working out that way
OK. In that case, you could buy another camera for the wide view, and do not set that camera to trigger on motion. Not a cheap solution, but a solution.
Johnny290 wrote:
.......Arlo Pro 2 with this Zone detection which up to now seems to be useless outside if it's raining snowing a shadow goes into my zone so it's pretty useless
Just my thoughts all along, pixel based motion detection works well in controlled environments (typically indoors) away from weather and other “zone” interfering factors. If you’re lucky, locating camera in a perfect spot, like a quiet backyard, you may get away without as many false triggers as locating it on a driveway.
