PRO 2 Outside Through A Window.
  • 1 Reply
  • 1032 Views
Riverchirp
I am wondering if there is anything I might be able to do to tweek one of my Pro 2 cameras or system in order to allow a camera to work inside pointing outside through a window.  This way I'm able to plug in the camera to electricity not worrying about the battery running low while I am away/out of town.
steve_t
Master Master
You can have the camera inside and point it out a window BUT it will not detect motion. You can use another Arlo camera or an Arlo security light (or possibly other devices with 3rd party integration) to trigger the indoor Pro 2.
If you use an Arlo Q or Arlo Baby, these can be pointed out a window and detect motion as they run off pixel change detection rather than an IR sensor
  • 1 Reply
  • 1033 Views
