PRO 2 App Design - Go Direst To Live View?
  • 1 Reply
  • 1148 Views
DarwinsFlinch
Hi gang... I installed a system in our house and I am generally pleased with the Pro 2. I do, however, have an issue with the Android application. I returned a Ring system for other reasons but when I recieved a motion notification it went straight to live view which seems a no-brainer to me. With the Pro 2, when there is motion detected and I select the push notification, I have to log in then select the live-view for whichever cam. Is there a setting I am missing somwhere?
Thanks for your time,
Rick
JessicaP
Hi DarwinsFlinch,
When selecting the push notification, the Arlo app should open without you needing to log back in (unless you logged yourself out manually) and you will need to play the live stream from which camera you want to view from.
  • 1 Reply
  • 1148 Views
