PAN function is not working.
A few days ago I was looking at my library and noticed that the "PAN" function is not working. Instead, a circle with a square in the middle appears in the middle of the viewing area. It also does not work in the enlarged screen.
No. I am referring to the, "Pan and Zoom" function which is on the lower left of the recorded clip. It appears as a magnifying glass which when you hover over, displays, "Pan and Zoom", and then when clicked on becomes a vertical column with a white dot that can be raised and lowered to Zoom. Then when you place the mouse over the viewing area, the mouse cursor becomes a hand which grips the scene when clicked allowing you to move the entire screen enabling you to, "Pan" the entire clip. I used to use it all the time and now it won't function.
Which browser are you using?
I have been using Chrome mostly and it worked fine. I also use Firefox occasionally and that used to work fine also. I have a case going with Arlo now and they are looking into the possibility of a bug in the code. I have also reset my hub to, "Factory Settings" and that also failed to resolve the pan function.
