Only one camera arlo pro 2 generated push email alert (material H3)
  • 2548 Views
Sytlistme
Hello
I have 2 camera Arlo Pr 2 (H3), but only one generated push email notification when motion is detected.
As the same time,both camera can be used in live view,  video rewards is done  I can watch all short video but without email alert.
I am in mode : geo + planning
Firmware 1.124.1.0_15483
Serial num : 52M17978AF4C8
Any idea ?
Sytlistme
I found it
Go to mode,
select Armed mode,
then edit each camera to specify 2 rules :
stick both records and push notification
end to re select the good mode (my case geo on mobile apps only)
Now it' s done
steve_t
Master Master
Edit the rule for the camera that doesn't send emails in the mode you use and you'll see a send emails box at the bottom. Tick/check that box. Save. It should work now
Sytlistme
thanks for reply,
but I have already stick option on my iphone (green case)
Mode/geolocalisation/push notification/stocked
Rodolphe
Sytlistme
I found it
Go to mode,
select Armed mode,
Now it' s done
  • 2549 Views
