One of the cameras stopped working. Tried spare battery but not working. Blinked amber and blue.
I bought a package that came with three cameras and a base station. After some time, one of the cameras stopped working. I assumed the battery was dead and replaced it with a spare - nothing. I charged the battery over night - nothing. I tossed it in a box and forgot about it for a few months but now I'm back at it. When plugging in the battery direct to the USB charger, the LED blinks amber and blue. For the first few moments, I can see the red night vision lights illuminated but eventually they turn off and all that remains is the blinking amber/blue LED. This should indicate a firmware update is in progress, but it's not connected to the base station or the internet. If I unplug the USB charger, the camera goes "dead." It won't sync, no lights flash, etc. Unrecognizable to the base station. Not sure what's going on here or how to get my camera back!
Rather than throwing it in a box and waiting while your warranty expires, use that warranty by clicking on the Contact Support link at the bottom here.
@Camanda wrote:
Did you get this issue resolved? My husband’s grandparents gifted us their set they no longer needed and we are getting the same issue. I’m just wondering if there’s anything else we can try. It won’t even let me do a factory reset on the 2 cameras with the problem.
Can you tell us if these are also Pro 2 cameras, or if they are a different model?
Have you tried removing the cameras from the account, and re-adding them? Have you tried adding them from both the app and my.arlo.com?
@Camanda wrote:
I’m not sure if his grandparents removed them from their original account
They have to do that before you can add them to yours.
@Camanda wrote:
I should still be able to do a factory reset, shouldn’t I?
AFAIK there is no factory reset for the Pro 2. You can remove the batteries to force a reboot, and you can resync. But you can't do a factory reset.
