One of the cameras flashes and clicks continuously while live. The other cameras work fine. We have resynced it and rebooted the base station. Any suggestions. This unit is only a week old.
Maybe the Camera goofed while doing the firmware update. You can try resettin the camera.
How can I reset my Arlo base station to the default values?
Also when you say "flashes" are you refering to the Blue LED ?
What do the different LED behaviors on my Arlo Wire-Free, Arlo Pro Wire-Free, or Arlo Pro 2 Wire-Fre...
Also make sure the Base Station and Cameras firmware are up to date.
Firmware-Release-Notes
The Base Station should be on FW: 1.10.0.9_23037
The Pro 2 cameras should be on FW: 1.125.11.1_25366
The Pro cameras should be on FW: 1.092.0.17_25364
You can check to see what firmware version you are on under the Settings\My Devices and then tap on a device next tap on Device Info.
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
