My Arlo Pro 2 camera named backyard recently started giving me notifications of movement. It never did previously. I have 2 that are set for human movement only and they work correctly. I first thought to reset the camera and add it as a new camera. It continues to to give me notifications even though as you can see in the attached image, "Backyard" cam is not selected to. Suggestions? Thanks.
If I understand how this works, if you move the camera to the inactive status, you will only receive Motion notifications. To completely disable notifications, you need to go to the Mode section and edit the rule for that camera to not send you any notifications.
Brian
