Notification Problem, No Recordings
  • 8 Replies
  • 3926 Views
02redcavi
Don’t know if it’s just me but for the past 2 months my arlo have been having intermittent not sending me notifications at all when a event happens and now just recently aren’t even recording motion. I’m hoping this is a software issue that maybe a update will fix permanently. Really regretting buying these cameras so far. I reset my base station every so often and sometimes it works. Thanks
ShayneS
@02redcavi
Have you tried to reboot the cameras by removing the battery/re-installing it & test again? Have you performed a successful motion detection test with the devices? I have attached an article here with instructions.
- How do I use the motion detection test for my Arlo device?
8 REPLIES 8
ShayneS
@02redcavi
jmmmmh
Same, although it only started today on one camera. Sigh.
02redcavi
I have not tried installed and reinstalled the batteries or doing a motion test. Only rebooting the base station. I don’t understand how that would fix the issue though. I have had nothing but problems with these cameras since buying them.
02redcavi
Did the motion test and is working fine
02redcavi
Removed devices from base station for both cameras and disconnected batteries and reinstalled and Motion recording and alert notifications are back up and working for now.
02redcavi
That worked thank you
BastropMan
Did it start after cold weather set in?
02redcavi
Yea it did coincidentally.
  • 8 Replies
  • 3927 Views
