  • 1 Reply
  • 969 Views
Gordone
Hi,
When I opend up the outdoor power cabel I found these paper, please see attached.
Does these mean I’m depending on the battery below 0 degree celcius?
And when above the battery will charge up again?
So I will loose some features below 0 degree celcius?
I’m planning to install at my cabin where you have typical 0 to negative/minus 10 degree celcius in the winter.
No.  It just means that the battery won't charge when the temperature is below 0C.
The camera works down to -20C, and will use the AC power whenever the cable is connected.  If the cable is always connected, you don't need the battery at all.  Though it is a good idea to keep it in the camera anyway, in case there is a power interruption (or if the cable comes loose).
  • 1 Reply
  • 970 Views
