Not honoring my Arlo Solar Panels that I purchased on Sept 2018??
In September 2018. I had purchased 2 sets of Arlo Pro 2 systems and 2 solar panels (VMA4600) for $1029.94. After 3 weeks, one of the solar panels stop working. I was run around for getting the replacement under the warranty. First, Netgear indicated they don't warranty Arlo solar panels. Then, for several months, I was getting nowhere with the Arlo people. Will some responsible person at Arlo answer to my problem???
As you prob found out Netgear and Arlo are separate companies now...
Any warranty would need to go thru Arlo.
Try here; https://www.arlo.com/en-us/support/contact.aspx
