- Trying to set the base station up, but simply cannot.
- i have to app. The power light in on, green. The internet light in on, green. The app discovers the device with the right serial number, I give it a name, and it returns no arlo device found.
- repeatedly.
- Powered off, restarted everything. Same outcome.
- cant even get started, sooo disappointed.
Is a VMB 4000, the menu above can’t even recognise that
any ideas. If it’ll be techie to solve, they are going back to the shop.
thanks
mark
In the app, can you click top right, Settings > My Devices and see if the base station is listed there?
