Need to rotate camera that images are upside down? Any way to mount so image is right side up?
Camera with Solar panel: to make the camera stable, I had to rotate the camera so far that the images are upside down. Is there a way to mount it so the image is right side up? I‘m using the mount with the ball and rod.
Since the camera is currently upside-down, why not use the video toggle to FLIP the view 180 degrees ?
It is in cameras settings under VIDEO ; Rotate Image 180˚
