Please provide more details on what the issue is.
@Youtrend There is an E-mail for Arlo to report scams. Not sure if they will respond or not but worth a try. It is near the bottom of this link page.
If the scammers are simpletons then you may be able to get away with just recovering the system through arlo support.
If the scammers have sold your arlo system access to hackers then your whole network could be compromised including any mobile devices your using on it so it would be prudent to seek advice from a cyber security expert.
You can private message any of the forum moderators here to state your case, like JessicaP.
Youtrend,
From the details you've provided so far, it sounds like you need to factory reset your Arlo system and then create a new Arlo account and re-onboard your system as new. For details on how to factory reset, take a look here: https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-SmartHub-or-base-station-to-the-default-values
Please note that Arlo support will never ask you for a password to troubleshoot. Please refer to this article for more information: https://kb.arlo.com/000062119/How-can-I-avoid-Arlo-support-scamshttps://kb.arlo.com/000062119/How-can-I-avoid-Arlo-support-scams
