Hi Everyone, My first post on here and hoping some of you seasoned owners can offer some help.
I'm trying to alter the schedule times - I've worked out how to add additional times, but some of the default times do not fit with my new plan. Is there a way of deleting them ? Maybe I'm missing something obvious, but I can't see how to remove them. Any advice greatly appreciated. Rob
If your not already, try and set up the schedule on a browser ( https://arlo.netgear.com )
It is so much easier than the apps.
On the web, to delete is just a click on the time frame... to add, just click on " + " , put in time and pick multi days if wanted
Tips;
if you go thru midnight, you must split up the time ... up to 1159pm and next day at 12 midnight to whenever
only one mode can run at a time
any camera NOT in the running mode is OFF
Tips;
Thanks for the reply and advice - I was trying to use the phone app to alter the schedule. I've opened up Arlo on my laptop and ' Hey presto' I can do everything I want to change the schedule with ease.
As you quite rightly say, it's far easier using that method.
Thanks again and if anything else crops up, I know I can rely on you guys.
