Multiple False Alerts
Hate to say it but I would completely reset the whole system and start fresh. WHile it's possible that your schedule isn't being followed as you think because you set it and are checking it with the app instead of a browser (the app has display issues that the web doesn't), I would play it safe and reset.
Note your device settings, modes, rules and schedule for easier rebuilding. Remove everything from Settings, My Devices. Hold the base reset button until the LEDs flash amber. Claim the base as new and then sync the cameras. Update firmware if prompted as you go. Then use a browser to set up your modes, rules and schedule as you need. You can use a mobile browser if you set it to use the desktop version of the site.
Sadly, that is what I did, but I am still getting duplicate messages.
Are you subscribed to Arlo Smart?
Since I know not what that is, No.
