How can o set up a mode and modify the sensitivity for multiple cameras. I have two cameras that are throwing multiple false alarms and the only option I see is setting up a mode where I can only modify one cameras sensitivity.
All cameras can have diff sense levels...
when you set up a custom mode, use the first camera and then save...go back and edit the custom mode to add additional cameras and set your sense level for each you add.
Where and how do you set up custom mode?
https://kb.arlo.com/1101750/How-do-I-create-a-mode-for-my-Arlo-Wire-Free-camera
