Mounting on vinyl outside home ?
Hey guys I just got the Arlo pro 2, it's quite nice besides some important computer security features missing.
Anyways, any idea on how to get the cameras mounted to the side of the house that uses vinyl siding?
Thanks!
Thanks!
It depends on what you're comfortable with. I'd suggest starting with some outdoor double-sided tape to test locations. Once satisfied, I've used both short and long screws (short to only attach to the siding, long to get to the wood underneath). I tend to prefer the corners where it's a vertical trim piece - less flexible than the siding itself.
I thought this guy had a good approach. Should work with Arlo also.
