Is it possible to create a new rule for all cameras to drop sensitivity once selected?
I'm trying to create a new mode/ rule called wind mode, in which all three of my cameras will drop sensitivity once selected.
Is that possible? When I try to create a new rule it only lets me select one, camera not all.
Thanks!
Thanks!
Yes it is possible to do so, I have one this way too..
The trick is to create a custom mode with one camera and SAVE it, then go back and EDIT the new mode to add the second and third cameras as needed.
Okay sounds like I was on the right track, but it didn't give me motion detection options for the next 2 cameras. It also made it look like it would record all three cameras when the first one went off.
Does that sound correct?
For the extra cameras, be sure to use the Add Device section of your rules. That will allow you to select the options you're looking for.
