Motion detectors triggering when system disarmed
  • 4 Replies
  • 2643 Views
jdsylvester
I have my system set up on a schedule to arm and disarm itself. The last few days I have gotten up before the disarm time and manually disarmed everything using the Disarm button at the top of the mode screen. This always had worked fine, however now when I walk past the cameras the motion detectors trigger and fire the events they are set for. Has anyone else had this happen or know how to fix it?
Probably fastest to remove all devices from your account and start fresh. It's a pain but should clear out any weirdnesses.
Start by rebooting the base. You may also want to reinsert the camera batteries to reset them to a known condition.
jdsylvester
Thanks for the suggestion. I did try these steps but still have the same issue. Is there anything else I can do at this point?
jdsylvester
This seems to do the trick. Thanks for your help.
  • 4 Replies
  • 2643 Views
