Motion detection on continuously with no detection. Tried removing and reinstalling.
  • 1 Reply
  • 1001 Views
RQUEST
The camera has worked flawlessly for a year. Now the amber motion detection light is lit and will not go off. Since it began, it does not report motion, but the camera works otherwise. I removed the app and re-installed, reset the base, and removed the camera battery and re-installed.
Test if able on the web with browser at   my.arlo.com
Create a new custom mode for that camera in case the original mode is glitched... test
OR
If NG above, remove all the cameras, reboot & reset base and set up as if new
( reset is hold reset for 10 secs till led(s)flash )
  • 1 Reply
  • 1002 Views
