  • 2 Replies
  • 5259 Views
Bird_watcher_34
The VMB3500 base station for my Arlo Pro 2 cameras has died.  What is a suitable replacement that is not going to force me into a subscription service?
The 7-day cloud storage is tied to your Pro 2 cameras, not the base.
All the bases are compatible, and none will require you to get a subscription for your existing cameras.  But when/if you replace the cameras (or add a new model), you will need a subscription for cloud storage.
Probably the best current base station for you is the VMB4540 smarthub.  Note that none of the newer hubs have a built-in siren, so if that feature is important to you, then you should look for a VMB4000 (likely you will need to purchase this used).
Bird_watcher_34
Thanks for the explanation.  Very helpful and much appreciated.
  • 2 Replies
  • 5260 Views
