  • 2 Replies
  • 1100 Views
maxim__s
So, I want to use a microphone on my PC to talk, so that the camera's loudspeaker will be speaking my voice
And, in the latest Google Chrome, the feature is not working! it says "the browser is incompatible, use the latest Google Chrome".
Adobe Flash is loaded OK, and I can see the live stream from the camera (delayed a bit)
But pressing the microphone button causes the above error to occur.
maxim__s
To add: using an app on the iPad - microphone option works fine.
ShayneS
Hi @maxim__s
What device are you experiencing this issue with? I just tested Google Chrome & was not able to reproduce the issue. Do you have another computer that you can try?
  • 2 Replies
  • 1101 Views
