I have lost the yellow bit out of the back of the base station where the LAN cable plugs into, anyone know where I can source a replacement?
Any comparable part can be purchased online or at a local electronics supply store. The catch is that you'll need to open the base, unsolder the old and solder in the new. The shell itself really isn't replaceable.
Or just purchase a replacement base station.
Thank you, I will do that.
Cheers
Thank you I will do that.
Cheers
