Looking For A Mount For VMB4500 Base
Hi,
My new Pro 2 system came with the VMB4500 base. I was trying to get a wall mount for the base, but can only find mounts for the VMB4000. The base design is not the same, so I guess the base will not fit. I can also find a mount for the VMB5000 (ultra). The desing seems similar, but I cannot see if the dimensions are the same. Is the mount for a VMB5000 compatible with the VMB4500 ?
0 REPLIES 0
