- Hi the app notifies me when a recording is made but when I go to library and click on today's date it only shows yesterday's recordings...
To help with this symptom you are experiencing, we suggest migrating to the latest Arlo app experience.
You can find more information here: https://kb.arlo.com/000062798/How-do-I-upgrade-my-Arlo-Secure-App-to-the-new-Arlo-experience#:~:text....
Best answers
You can find more information here: https://kb.arlo.com/000062798/How-do-I-upgrade-my-Arlo-Secure-App-to-the-new-Arlo-experience#:~:text=To%20upgrade%20to%20the%20new%20Arlo%20experience%3A,Tap%20Start%20Upgrade.
Does this happen day after day or are you now missing all recordings after a previous date? For the latter, you can remove one camera from your account and sync it again to see if that helps.
Thanks. It happens daily. Sometime in the afternoon it updates to the current day...
I have the same issue using Arlo Pro 2 cameras. I suspect its a timezone bug they have introduced.
We are +12:00 and as you say it fixes itself in the afternoon.
Bit of a pain as you need to wait 12 hours to see what triggered the notifications when this occurs.
Are the recordings missing on the web browser as well?
Which version of the Arlo app are you using?
For me, yes the recordings are the same on the web. And if you inspect the network traffic you can see duplicated data on the wrong day from the API.
Mobile Version: 4.19_28720
Cheers
John
Hi thanks for investigating this. Yes exact answer as zebarti above.
Also, Is this occurring with the Android or iOS app?
Thank you
Android
@Levicd Thanks, I sent you a PM with more info.
Yes, I am on Android also.
I also am having this issue for the last few weeks.
The previous days recordings show in the library until 12:00 midday, then after that the current days recordings display.
Happens on my iPhone -Arlo 4.19 (8201 released 19 August).
It also happens when I logon on my laptop.
I am in New Zealand Timezone.
Cheers
hello, I have this same problem.
I can only see yesterdays recordings on todays date.
I am in Melbourne Australia
IOS and Web both the same
All items up to date with OS/firmware etc.
Same issue here, iOS. In New Zealand - I get the notification but nothing shows in the library until the afternoon. Can this be resolved? It’s a bit hopeless if you get a notification but can’t see it until hours later…
My arlo2 when armed and detects motion, sends an alert to my phone. However the actual recording does not show up until a day later! I’m in Australia, is this because it’s using the server in NA which is at a different time? It used to send the recording right away
there is the same delay if I try a live recording. It doesn’t show up in the library until many hours later
Not been an issue for my system so far in BNE. I am still using the older UI though.
The app shows only the previous days recordings on today.
I get the notification but when I go in the app or web it only shows the previous days recordings.
At some point in the day it updates, but it is not until late afternoon / early evening.
Doesn't matter which device (camera or doorbell)
IOS: 17.5.1
App ver: 4.19
Devices all up to date
I am in Melbourne, Australia.
i don't have hope given my experience with arlo support in the past and how arlo has become a money grabbing company, not a customer service or product company.
Yes I agree the support is non existent with this issue, likely a ploy to force a plan upgrade or similar.
I see the acknowledgment of the issue here:
https://www.arlo.com/en-nz/support
Some customers in Australia and New Zealand regions may be experiencing problems with live streaming and motion recordings. We are working to resolve this issue, please see status.arlo.com for the latest information.
But that status link tells
me all systems are working and there’s no recent incidents open?
@M-G- Thank you for the information,
The Arlo development team is currently investigating reports of this behavior. We will provide an update as soon as we have more information to share with the community.
HI @fozarlo
Are you still experiencing this symptom?
May I ask which troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
Yes still experiencing this. I tried removing the camera from the hub and then adding them back. Still have a many hours delay. I get the motion alert, the red dot appears in the library, but when I open the library there is no recording and the dot disappears However the device view of the camera shows the frozen motion that was detected!
