Landscape view does not allow you to use slider, even after reinstalling the app. Slider does work in portrait view but that’s too small.
5 videos per line in landscape view is way too small. There should be 3 videos in a row while in landscape view. Who designs this stuff?
Hi JrC680,
Is this happening on the Arlo iOS app or Arlo Android app?
iOS. You need to move the landscape mode video slide button back in the video frame. Otherwise it’s useless. I’ve had to turn view n use slider in portrait mode, constantly , repeatedly, then back to landscape, and that’s not acceptable.
Are you running the 3.5.12 app?
I had this issue a while back with the iPhone 12 mini, but it was fixed - and is not happening with 3.5.12.
