LOCAL USB STOPPED RECORDING
My 256 Gb usb stopped working all of a sudden after 4 years.
I restarted the device, unplugged it and plugged back, changed USB slots, deleted videos for more space.
No luck.
What's going on?
#localusb #usb
Does it work properly in a PC? Try copying something to it as a test.
Works properly with PC
How much data did you try copying to the drive?
I guess you could try reformatting it (in the PC) as FAT32. If you do that, I suggest not using the quick format.
Do you have another drive you can try? It needs to be at least 16 GB.
I had to get a new USB. But other one works fine on PC but not on arlo
