  • 4 Replies
  • 1714 Views
lendelbogdan
My 256 Gb usb stopped working all of a sudden after 4 years.
I restarted the device, unplugged it and plugged back, changed USB slots, deleted videos for more space.
No luck.
What's going on?
#localusb  #usb
Does it work properly in a PC?  Try copying something to it as a test.
lendelbogdan
Works properly with PC
How much data did you try copying to the drive?
I guess you could try reformatting it (in the PC) as FAT32.  If you do that, I suggest not using the quick format.
Do you have another drive you can try?  It needs to be at least 16 GB.
lendelbogdan
I had to get a new USB. But other one works fine on PC but not on arlo
  • 4 Replies
  • 1715 Views
