Is there a way to turn on/off motion individually for each camera?
Is there a way to turn on/off motion individually for each camera? My 2 outside cameras work great with about 50% sensitivity, but the single camera I have inside, even at lowest setting, triggers the notification way too much, would prefer to turn off motion for the inside camera and leave on the 2 outside ones. Thanks
@C2078 wrote:
...would prefer to turn off motion for the inside camera and leave on the 2 outside ones.
Edit the rules that start the recording and remove the indoor camera from the rule, or change the rule so that it does not trigger when it senses movement. (Then do the following = nothing.)
What are modes and rules and how does Arlo use them?
Just another user
