Arlo pro 2 always showing 0%
  • 4 Replies
  • 1474 Views
  • 5 In Conversation
mm1233
Hello, so I have a problem with my new arlo pro 2 camera. I think its something wrong with charging. It always shows that battery is low (on 0%), i tried charging it all night and I have  also changed the battery from another camera, and its still the same. Did anyone had the same problem?
Thank you
ShayneS
Hi @mm1233
Does this "0%" show on the web browser as well?
Try removing and resyncing the camera.
Look4Answ
I had the same problem (over a year ago) when I tried to power my camera with a non-Arlo power adaptor.   My system has two cameras and came with one adaptor.  I wanted my system operating with both cameras on AC power.  So I had to buy another battery in order to get a second adaptor.  (could not buy just an adaptor).  I have not had the described problem using the Arlo adaptor and cable.
If you are seeing 0% charge when you put in a charged battery from another camera, then I suggest exchanging the camera with the seller.  If that is no longer possible, then contact support.  https://www.arlo.com/en-us/support/contact.aspx
Though as already suggested, first confirm that you are seeing this status in both the app and the web client.
  • 4 Replies
  • 1475 Views
  • 5 In Conversation
