Is the VMA1000 indoor/outdoor mount compatible with Arlo Pro 2
Will I be able to run continuous power to a pro 2 using this mount?
there are two models.... the newer one has a smaller lock wheel....( old design vs new )
The new version fixes the issue or you can use a regular 1/4-20 nut
TomMac, thanks for the reply..here is the link to an amazon purchase. Is there a way to be certain I’m getting the newer model?
