Is the VMA1000 indoor/outdoor mount compatible with Arlo Pro 2
  • 2 Replies
  • 995 Views
muskratlove
Will I be able to run continuous power to a pro 2 using this mount?
there are two models.... the newer one has a smaller lock wheel....( old design vs new )
The new version fixes the issue or you can use a regular 1/4-20 nut
muskratlove
TomMac, thanks for the reply..here is the link to an amazon purchase.  Is there a way to be certain I’m getting the newer model?
https://www.amazon.com/NETGEAR-Indoor-Outdoor-Mount-Black/dp/B01D2PHVS8/ref=cm_cr_arp_d_product_top?...
  • 2 Replies
  • 996 Views
