Is it worth paying for 4K than 1080p?
Is it worth paying for the 4 k bs th 1080p
"It depends." (TM)
4k is certainly higher resolution than 1080p but the Ultra cameras also have a much wider angle of view so each pixel captures a smaller part of the overall view. Only testing in your situation would give you the true answer. Just be sure you have a return privilege when trying them out.
