Is it possible only send notification if motion detection lasts for more than 3-4 seconds?
  • 8 Replies
  • 3461 Views
sojjan
Hello!
Is it possible only sent out a notification if the motion detection last for more than 3-4 seconds.
If a bird flying by for 1sec, i don't wont to get notified. Thats a false alarm.
Dannybear
You can reduce the motion sensitivity in the mode camera rules at the risk of reducing detection distance.
Alternatively you can use smart plan to filter event types at a cost.
8 REPLIES 8
Dannybear
sojjan
Thank you!
I will try the smart with AI. With the detection of people only.
sojjan
Hi!
I noticed that the Activity Zone doesen't work anymore after im subscribing the arlo smart.
It worked before. "using battery"
Dannybear
You need to have power applied to the camera to setup the smart activity zones, then you can disconnect and they should still be active.
Hope this helps.
sojjan
Ok, thank you!
Another question now when i have the arlo smart. I have only selected "people" for detection. But just recently i got a notification and a video that detected a cat that walked by.
sojjan
Forgot to mention that it aslo was identified as a "animal" in the video.
Dannybear
sojjan
Yes, have done that.
I will see what happens. If it's still detects animals i guess i contact Arlo chat or something.
Thanks!
  • 8 Replies
  • 3462 Views
